Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
My 1985 Capri Cuddy (outboard) was stored in a garage until I bought it in 2007. So it was dry and clean and showed no rot or water damage, although there is a shaddow in the bilge/ski locker so I know water has been in there from time to time.
While working on the boat I was impressed on how much glass and gelcoat they put on the inside of the transom and stringers and floor. It rained on the boat the other day and water sat in puddles and did not sink in (that I can tell). BUT on close inspection I found something that really made me shake my head in disbelief....
After doing such a great job of sealing up the wood from water, they went and drilled the hole for the drain and didn't bother to seal the exposed wood in the transom!!!!! Gee, ya think it should be sealed?
I'm going to remove the entire drain assembly (the big brass disk that takes the brass pipe thread plug) and paint the inside of the hole with epoxy.
The good news is when pressed with a screwdriver, the plywood is solid. And I can clearly see that this is a plywood that is made of many thin veneers, not the 4 or 5 thick veneers that regular ply is made from. So my guess is this is a marine grade plywood transom.
I pulled out the brochure for the Capri line, and it states "Wood components are preservative-treated. Sealed for lasting strength." Does not specifically say they are Pressure Treated, just preserative-treated. Don't know if its one and the same.
Maybe that's why they didn't seal the exposed plywood in the drain hole?
