Re: transom and floor replacement
I replaced the transom in my boat and did it all from the top by cutting the glass away over the rotted plywood core. Replaced it with cdx exterior plywood, layered and epoxy glued to within 1/8 or so of orginal thickness. Then encapuslated the whole new core in epoxy. Bought 5 gal of epoxy, used 1.3 gal in the transom and 3 gal in coating the new wood floors on both sides (2 coats) and replacing the stringers with new wood and glassing them in. Ended up using a total of 4 gal. Learned alot on getting the old wood out and the new in and it was really not all that difficult. Job is done and strong or stronger than new.
