islandboat
Thread starter- Joined
- Apr 10, 2004
- 127
This is not a question about whether or not to tow a 6000lb boat in overdrive. This is a question about controlling the lockup convertor in a 96' Tahoe. I tow about 65 mph and the engine rpm in "drive" is only about 1850. That is too low in my opinion. If I drop the transmission shifter into "3rd", the engine rpm is over 2700 rpm at 65mph. If I leave the shifter in "drive', and hit a small hill, the rpm will hold at about 2300 rpm for a while and then shift back into overdrive and the engine rpm is then too low. I can't let it keep shifting in and out of overdrive but the rpm is good when it is in 4th gear and out of overdrive.<br /> Question; Has anyone heard of a transmission control device that can disengage or control overdrive and still let it shift into 4th? I have no button on the shifter to control overdrive like some Ford trucks. I do not want to raise all of my shift points (at full throtle) like some of the high performance chips will do.
