Tranny Cooler vs. Synthetic Fluid
hibbert6
I've been told by several people that the tranny (automatic) on my vehicle is known for being weak. My new boat/trailer is heavier than the last one, but well under the weight limit. 2 shops have recommended a tranny cooler; another said that, for the same price, flushing & replacing with synthetic fluid would actually be a better choice as it can withstand much higher temps. Each option costs about $225. Until I can save for a sturdier vehicle, which one would be the better option?
Dave
etracer68
Ensign
Re: Tranny Cooler vs. Synthetic Fluid
What Vehicle, and how much weight???? You will still have the heat with syn oil, but it does help. I would go with the cooler, and syn oil.
kenmyfam
Tranny cooler is cheap insurance against frying the transmission. First thing I put on our Trailblazer was an additional one.
What vehicle and how much weight anyway ???
kenmyfam
Fitting the cooler is a great opportunity to change the fluid and filter anyway. Personally I can take or leave synthetic fluid but I will take a cool transmission every time.
N3UP
Both.
Cooler first, then syn fluid......belt & suspenders.
Fishing Dude too
Both.
Agree, synthtic runs cooler, but temp is the enemy. Check auto parts store for cooler, easy enough to do yourself Did mine in abut an hour, or two, cost $75.00 US. Then have shop change filter, and fluid.
hibbert6
Thanks, people. The vehicle is a Frod Freestar minivan - and not the "tow" model, either. It pulled our old 15' tri hull no problem. But the new boat & trailer weigh 2800# - well under the 3500# tow capacity of the van, but, as I said, several mechanics said it has a notoriously weak transmission.
After weighing the choices, we're buying a used Suburban. Problem solved. :)
Dave
CVX20SPRINT
If the Burban doesn't have a tow package I would still put a cooler on it.Did tranny's at a GM Dealer for 15 years.JMHO.
