Trailer wheel balancing
orion208
I have never seen this addressed but can you or does anyone have their trailer wheels "balanced" as you would with a car.It would seem beneficial to have this done if it can be done.Any comments?
bubbakat
Re: Trailer wheels??
I always have mine balanced. Why I don't know just seems like the thing to do.<br />I suppose it comes from all those years of selling and mounting tires.
sangerwaker
I also always have mine balanced. I've been told by tire places it isn't necessary, since it's ONLY a trailer. I would guess an out of balance tire could trash bearings and spindles. I guess that's my main reason for having it done. Maybe we are just wasting our money, but it sure seems like cheap insurance to me.
Mark42
The larger the diameter, the more important balance is. Even though the small 8" rims turn the fastest, any out of balance condition is not far enough from the axle or heavy enough to cause any noticable vibrations. On the other hand, I have seen 14" rims bouncing on a tandem trailer like a basketball. Imagine what a few hours of that does to the life of the springs, axles and bearings.
snowshoe
I always have had mine balanced for the boat, for the RV, for the quadtrailer and the utility trailer. It makes sense that a balanced wheel will not be stressing the suspension as much as an unbalanced wheel. The tire dealers tell me it not needed also but I insist on all wheels being balanced.
Hydra-sport_Road-kill
I'd think the consideration is due to how much time you spend towing at highway speed and how close you expect to get to the millage rating of the tire rather than old age (the tire, not the driver/boat captain). My tires get replaced about every ten years. The ramp is only ~five miles away and I don't get past 40 mph unless going for beer as well. :) No need for balance if you're near the water IMHO. Now, a cross country trip begs all the preparation possible for the tires, hubs and a blessing by your clergyman I'd say.
Silverbullet555
I balance mine. Most shops will tell you that you don't need to. If that held true than why not leave front tires on a RWD or rear tires on a FWD unbalanced.
They will still wobble, bounce, shake, etc.
When I raced radio controlled cars we balanced the tires. It's such a small expense in the grand scheme of things.
ufm82
Master Chief Petty Officer
Balance them. Not only will the improved ride save wear and tear on your trailer components, it will also save wear on your boat. Take any boat that has anything bolted or screwed together anywhere and shake it for a while and those fasteners will loosen. Then you get rubbing and wear. I've seen consoles on bass boats loosen up, handrails and t-tops get loose, electronics fail (especially fish finders and other electronics) due to vibration and it can also work-harden wiring in your harnesses. My buddy never balanced the tires on his single axle bass boat trailer despite my constant warnings and it bit him during a trip to Tennessee a few years back. His fuel line from the tank to the engine rubbed for 300 miles against an edge in the stern and when he launched for his tournament he had a fuel leak and the engine wouldn't run. Took him 2 hours to get it fixed and cost him fishing time and possibly money in the T. All because his tires were shaking so much. Wouldn't have happened had the vibration not been there IMHO.
'78 Crusader
I've had the "Experts" at Firestone, Discount tire, Hibdon tire etc all tell me NOT to balance a trailer tire.....screw them, I balance them anyway. I do a lot of "Highway speed" driving and if a car tire needs balancing, trailer tires do too.
MH Hawker
I also have mine balanced , and yes you will be told its not needed and thier right it isnt needed from a trailer control point of view, but it reduces vibrations, and makes the gas milage a tad better and improves tire life, altho age allways gets mine not wear, but vibration can and will cause damage to the boat and trailer, and I cant speak for ever one but boat stuff costs enough as is with out replacing items that 10.00 will stop, I hate pulling in to prep the boat and finding something shook lose or broke and having to pull out of line to make a repair in the parking lot, I often say ok if it damages my boat are your gona pay for the repairs, lolol and you get the deer in the headlights look. Back in the old days when ever one ran bias tires only the front tires got balanced ( steering tires ) and no one ever rotated them and you got about 15,000 miles out of a set. Todays high speed radials need to be balanced and rotated so you can get 60,000.
Dave1251
I sell Eagle and Heritage trailers, both manufacturers do not balance the trailer tires. If you balance your trailer trailers, you are doing it to make yourself feel better and not the boat/trailer.
BoatNoobie
I bought my trailer tires from Discount Tires early this year and they balanced them.
oldjeep
Never had a trailer tire balanced on any boat trailer, car trailer or sled trailer that I've owned. Can't say that I've ever seen a mounted trailer tire for sale that had weights on it either.
'78 Crusader
I'm not saying they wouldn't balance them, only said that the experts there told me not to.
jayhanig
When i bought my 5' X 10' utility trailer, it bounced around quite noticeably until I got the wheels balanced. When I bought my boat last year, I had to replace the wheels and tires anyway so I had them balanced before I mounted them on the boat trailer. I fail to see a downside.
Volphin
EVERY high speed tire and wheel assembly should be dynamically balanced. Wheel balance, in extreme cases, can affect the handling of the trailer and cause premature tire wear. Anyone who says otherwise needs their certification pulled. LOL
V
Volphin
I have worked in the wheel service industry for over 30 years. What I have learned from engineers (much smarter than myself for sure...) is that vibration is measured in destructive force. If a wheel assembly goes unbalanced, it stands to reason that the vibration will travel throughout the supporting bearings, suspension and trailer frame and transfer some of that energy to the tow vehicle through the hitch. This would happen at varying frequencies based on load, speed and amount of imbalance present along the two dynamic planes.
For instance, when your rear car tires need balancing, you feel vibration from your seat. When the front wheels are unbalanced, you feel it in the steering wheel. Ever wonder why? Because destructive force travels with varying harmonics through rigid metals. And while it is annoying, what many folks overlook is the repeated destructive force being applied to the, say, steering components to bring you that vibration up to the steering wheel.
That said, trailers are no different. We won't feel the vibration as much, because we only are connected via a pintle or tow ball to the frame. Does that make the forces involved any less destructive? No. It has simply been isolated. However, I found that U-haul tow dollies vibrate like hell without a vehicle on them due to their very short tongue length.
Anyway, I'm sure you are all bored by now...
V
