Trailer Too Low
gtaeza
Is there any lifter block to raise the trailer<br />chassis for 3". Pls. advise. Thanks
JB
Re: Trailer Too Low
Tell us more about your trailer, George.
roscoe
Re: Trailer Too Low
Why is the trailer too low?<br />Too low at the hitch?<br />Too low that the motor hits?<br /><br />Step down hitch inserts are available.<br />May have to tilt motor up for trailering.<br /><br />Raising the trailer (and boat) by 3 inches may make launching very difficult ( depending on the launches you use).
SoulWinner
Re: Trailer Too Low
If the spring positoning lug is the same size as the ones on leaf springs on trucks, then any lifting block should work with the right length u-bolts, but I think that springs with a taller arch would be better.
