redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,378
If you are talking about the signal that gets sent to the brakes from your brake controller in your cab, that's a yes.
While you are buying parts, don't forget a breakaway kit
I'll have to research that. On the face of it, breaking away form the truck does not sound like a good idea.
Remember, it's a trailer, not a Christmas tree! :eyebrows:you've never seen me with electrical stuff...
Should be around $50, just a breakaway switch and a battery/holder. You need it to be legal as a way to actuate the brakes if the trailer leaves you.
http://www.etrailer.com/Trailer-Brea...50-85-315.html
interesting I'm supposed to have breaks on anything over 1500 lbs - thats not much weight. http://www.brakebuddy.com/Towing-Laws although this one says 3000 http://www.glen-l.com/designs/trailer/trailer-laws.html
This one is 1500 and states over 3000 lbs require breakaway - but is that trailer only or loaded weight I wonder.
http://towingworld.com/towinglawsbystate.cfm?state2=TN
I've never seen a breakaway on a trailer (not that I'm looking but...)
I've never seen a trailer that has brakes without a breakaway. On a surge brake setup it is just a cable leading to the actuator that mechanically pulls and locks the brake piston. For electric it is a NC switch that when pulled opens the path between the battery and brakes and locks the brakes up at full power.
The 3000lbs requires breakaway would be the weight that the trailer is licensed at (typically max loaded weight) - or max loaded weight if they don't license by weight in your state.
What size tires?
Never heard about the 12% reduction for tandem. Where did you read that?
Just so you know, the weight for a load range C depends on the size tire it is. A load Range C ST225/75R15 will be higher than a load range C ST205/75R15Most boat trailer tires have a load range of B, C, or D. If a tire has load range C, it can carry 1,820 pounds.
