Trailer recommendation for 2006 Maxum 2400 SD
RatFish
Hi All,
I want to buy a boat trailer for my boat, specifically a tandem axle, roller trailer. I never bought a trailer before because I always got one with the boat. Does anybody have a recommendation on a brand and model? Any advice would be appreciated. Ratfish.
Here's the stats on my boat:
Boat: Maxum 2400 SD
Year: 2006
LOA: 24? 2?
Beam: 8? 6?
Dry Weight: 5500 lbs.
Fuel Capacity: 75 gal
Water Capacity: 15 gal
sundowner205
Re: Trailer recommendation for 2006 Maxum 2400 SD
Also, you're going to want a bunk trailer so you can just idle/float it on... way too much work to get that beast on a roller. Depending on the draft and the incline of your ramp you may be able to do it, if that is what your heart is set on.
Why the roller preference?
RatFish
Thanks Sundowner, I appreciate the feedback. I'll be towing with a GMC Sierra, 9600lbs towing capacity. I was thinking I would need a trailer with about 6800 lb capacity.
Most ramps I deal with are shallow and/or end abruptly so it may be tough to float the boat on or off the trailer. The water is tidal so water conditions vary. Most of the ramps are cement but only go so far into the water. You run the risk of backing the trailer off the end of the ramp into the water or at best soft mud. I think a roller trailer would probably be best in these conditions.
sundowner205
You're going to need to get a roller in just as deep, possibly even deeper because of the added height of the roller carriages. You really should aim for a bunk style with drop axles like tasha suggested. With a roller you will probably be in for some serious winching time.
They also make roller bunks for bunk style trailers, however you would have to find a pair that would be the same length as the bunks that you remove.
I would stick with an 8,000lb capacity as we suggested. The price difference will be marginal, and it's never a problem to have that extra capacity.
Also, try and launch and retrieve as close to high tide as you can. This will ease the process a little by allowing you to take advantage of the deeper water at the ramp.
RatFish
Thanks for the advice guys. I like the drop axle idea, every little bit helps. I will definitely consider it. You sold me on the heaver trailer. Extra capacity is a good thing. I don?t like to push things to the limit. You usually get burned if you do.
Good points regarding the added height of the roller carriages and the extreme winch work out. Years ago a buddy of mine had a roller trailer with a 25? Sea Ray (comparable in size and weight to my boat). We used to take shifts, yes shifts not turns, winching the boat on the trailer. We both felt like two bowls of Jello when we finally got that beast on the trailer. An electric winch would be a must with rollers but I can?t guarantee I?d be using the same tow vehicle all the time so wiring becomes an issue. That?s a minus.
I?m definitely leaning towards the bunk trailer now. Best case, I would get the drop axles with bunk glides. That would work. Since I only trailer a couple of times a year I think a trailer without the drop axles would work okay.
If I buy new do you guys have any recommendations on brands (EZ Loader, Trail Rite, and Shore Land?r to name a few)? Any idea of the cost for a new trailer? I figured I was looking at anywhere from $4000 to $5000 but some off-brand name outfits seem to offer some pretty good deals.
sundowner205
The brand names are always good, however, I bet you can find a great deal on a lesser known company's trailer. If you're not sure how to compare quality, all you have to do is examine a brand name trailer - the materials, construction, warranty, etc, and then compare that to a lesser known company's trailer.
You can probably find a good used one as well. Check your local marinas, boatyards, and craigslist...even ebay.
You can expect to spend anywhere from $1500 for a used unit all the way to $5000+ for a new one.
tashasdaddy
Continental, makes a great trailer, altleast get a galvinized trailer, or up grade to aluminum.
sundowner205
That's a nice trailer and the price is good as well. If you can get that same trailer locally at that price I would consider it.
tashasdaddy
and it is the next best thing to a drop axle, it is a torsion suspension. i have the same set up on my trailer. i would check with local dealer, and have them set it up for your boat.
