Trailer harness has no power for running lights
Javelin 353
My 1998 f150 has lost power to the harness connector on the runnig light plug, This is a factory wire job, I traced the wires back some but then it started to rain, can I get a new harness and plug it in like the aftermarket ones ? what else should I check? Thanks
shipoffools
Re: Trailer harness has no power for running lights
Check your manual I'm not sure what year it started but the newer Ford F series have a fused circut for the trailer harness.
gstanton
Just had the same problem with my '02 F-150. Turns out that inside the trucks connector is another "pinned" connector that corroded. I do salt water in the winter and this must have gotten to it? I replaced the connector with one from a NAPA store but later found the same thing at Wally World for a buck less - - ($9.00)<br /><br />Anyway, this new one has screw terminals inside. I've installed this kind before and never had a problem. In my opinion, you're better off to replace it, if you're comfortable doing it.
burp
There is a 20 amp fuse (yellow color, ATC type fuse) in the fuse box under the hood that provides power for the trailer lights. Use a voltmeter to check for 12 volts between the white and brown trailer wires with the lights turned on.
Javelin 353
Thanks BURP the fuse under the hood in the box was blown
burp
Good to hear that it was an easy fix.
heycods
Originally posted by Javelin 353:<br /> Thanks BURP the fuse under the hood in the box was blown
Happens regularly when backing trailer in water with lights on.
solidwaste
I always unplug my lights before backing in the water its part of my straps off plug in rutein..Is this what most people do?
Cold water on hot bulbs is a good way to pop them so disconnecting the harness is the recommended procedure.
