Trailer Brakes
Trailer Brakes
  • E-coated.
    Votes: 1 25.0%
  • Silver Cadmium.
    Votes: 0 0.0%
  • Stainless Steel.
    Votes: 2 50.0%
  • None, it will rust anyways.
    Votes: 1 25.0%
  • Total voters
    4
lmannyr
Master Chief Petty Officer
Trying to decide which Kodiak brakes I should get. I definetly want disc. Not sure if I should go with e-coated, silver, or stainess.
I can get 2 new axles with kodiak e-coated disc brakes for 1k shipped. Will these ecoated brakes last at least 5 years? Or should I get the stainless. It's an extra 400 bucks for the stainless setup.
tashasdaddy
Re: Trailer Brakes
i have stainless on my Chris Craft Deckboat, exclusive salt water use. in Ormand or the Keys. the trailer is a 1999 and the disc have never been replaced. still look like new. 4800 lb boat. of course they have the washdown system.
lmannyr
Re: Trailer Brakes
I keep hearing about this "Washdown System." What is it? What does it look like? Is it something I can put together from HD parts and install?
Thanks
TilliamWe
Banned
Re: Trailer Brakes
Stailess is your best bet.
The "washdown" on my 97 Shorlander was just a plastic type fitting in each brake backing plate, with clear plastic tubing between them. Then on one fender was a standard female garden hose connector, with a piece of hose that "T"ed into the hose between the brakes. So if you could find an appropriate little fitting that you could attach to your brake backing plate that would allow water to rinse the whole brake caliper/rotor, and you are handy, I would say yes, it's possible to build your own.
