sailors hornpipe
Thread starter- Joined
- Apr 21, 2010
- 53
ok today about 8 pm as it was getting dusk i backed up my truck (2009 ford f 150 with 7269 mi) and hooked up my trailer lights in the drive way to check them - ive had the boat out once for a maintenance run (1992 180 nitro fs /150 hp johnston evinrude 17.5 ft) i purchased the bost a month ago and am trying to get it ready for the season-now with the lights hooked up all the trailer lights light up including the brake lights but the problem is the brake lights do not brighten( to signal actual braking) when the i step on the truck brake pedal - i did notice that the drivers side trailer brake light brightens ever so slightly but almost unnoticeable unless you are looking really hard at a couple of feet away- also the blinkers do not work on the trailer but the brake lights are functioning and stay lit - from reading other threads on this subject i checked to see if the trailer brake lights were grounded and they are ,i can see the ground wire screwed into the frame of the trailer on each side- i read my trucks fuse and relay info and only saw one fuse in the whole fuse box having to do with trailer lighting it was marked (trailer brakes) however upon inspection the fuse was good - i did see in the truck manual that there are relays that are marked ( right trailer turn signal) and ( left trailer turn signal) but unless im wrong i dont think a relay would go bad on a 6 mo old truck, and isnt the fuse suppose to blow before the relay is damaged anyway? im guessing it has some thing to do with with bulbs inside the the trailer brake lights themselves? or could it be the trailer connection plug that connects to the truck? i also checked all visible wiring for exposed / stripped areas- oh and yes blinkers and brake lights on the truck work fine- i did see two wires hanging down with metal connectors on them wrapped around the frame of trailer/ drivers side brake light side - these two wires are brown and white and are not long enough if unravelled to reach the passengers side trailer brake light - dont know if those two wires have something to do with it? please please help / im stumped!
