Trailer Bearing Repair 101
CaneCutter79
First, I found and read the sticky at the top of the forum:
http://forums.iboats.com/trailers-towing/re-wheel-bearing-sizes-294110.html
I have a 2-wheel boat trailer (1979) with the original axle and the seals on the hubs need to be replaced. The wheels are also making a rubbing noise that is comone with rusty bearings. I want to fully replace the bearings and wheel races but I do not know how to determine what size I have. I do not have brakes on the trailer, just a simple axle setup. I do know the wheel hubs are a 5-lug.
A) How do I acurately determine the size of my spindle? Tape measure or micrometer?
B) How do I acurately deterime what size bearings I need? Is 3/4" the thickness?
C) How do I determine the size of the races?
D) How do I determine the size of the seal?
E) Just how much grease are you supposed to pack/use with a bearing buddy? I've seen many threads where people use too much, how much it supposed to be?
F) Anyone know where I can buy a race tool as well?
I'm mechanically sound enough to repalce my bearings and races. I watched a few videos on Youtube and read some instructions on this and it looks really simple. I just need the correct parts for the job and a race tool as well as a bearing packer.
If anyone can give me some detailed instructions on how to determine what I have, I'm glad to get my hands "really greasy" and do this myself and save some serious cash vs. paying someone to do an easy job. All I need to know is what to order online.
minuteman62-64
Re: Trailer Bearing Repair 101
If you bring the hold bearings and seals to a good trailer supply shop, they will be able to determine the correct size components and sell them to you.
Allbutwet
CaneCutter79 Remove your bearings and clean them up. There is usally a part number on them. Normally the rule is not to beat steal to steal; but races are hardend. Get yourself a peice of round stock or even a long 1/2 inch bolt. Six to Twelve inches long to use as a drift, and drive the races out moving back and fourth to keep it coming out evenly. The seal should have a part number on it too. Napa auto parts or any other auto parts store should be able to cross the numbers and get them for you. They might even have them here at iboats. With a little patience you can drive the new races in the same way.
fat fanny
Pull the hub and take it with you.
kfa4303
Banned
+1. I would take them with you just to be sure. Most hubs are generally 1"-1 1/2" and generally run about $20 a pair. There are several good vids on youtube that can walk you through the job. I recently changed mine for the first time and it wasn't too bad, just kinda messy thanks to all the new/old grease.
CaneCutter79
Thanks. I have watched several videos on Youtube and it looks like a piece of cake. My boat mechanic told me he would walk me through the steps FOC when I go pick it up! NICE! So now I will have someone with experience helping me. My main concern was how to determine the size/etc. If there are part numbers, that's even better. I can definately take the hub and the parts to a local parts supply store. Hopefully they will have a pair in stock as I will be 4hrs from home when changing.
To determine bearing sizes you measure the spindle diameter. A straight spindle will have the same bearings front and rear. You measure the diameter of the spindle where the two bearings sit. Straight spindles are usually 1-inch diameter. Yes, you use a caliper or micrometer. Note that I said measure "diameter" -- not "circumference". Heavier duty axles, (3500# for example) have a "step" on the spindle where the rear bearing sits. The front bearing will be 1-inch and the rear will be 1-3/16. But as was mentioned, clean up the bearings and the numbers will be very evident. Any store that sells auto parts, farm stores, and sporting goods stores like Cabelas and Bass Pro have the bearings. When you are done with this project, make certain you understand how to adjust the bearing preload or you will be doing this job again.
I must have had some bad beer -- straight spindles are available with 1 inch inner and outer bearings, but most boat trailers with straight spindles have 1-1/16 iinch innter and outer bearings. 3500# axles have 1-1/16 inch outer and 1-3/8 inner bearings.
dingbat
If you'd ever witnessed what happens to harden steel when it "explodes" from being hit by something hard, you'd use a brass drift to drive out the old race. At least wear a pair of safety glasses
Wind dog
Be sure to take your old parts (or at least one side) when you make your parts run, it's amazing how many different hubs / bearings there are, and they all look the same when you don't have an example to look at.
bruceb58
The part numbers are on the parts themselves. Can't get much better than that.
bruceb58
The part #'s are not allways there in my experiance.
On bearings and races? They have always been on there in the 30+ years I have been looking at bearings. Sometimes the numbers on seals can be a little tough to track down but they are usually on there as well.
stylesabu
Master Chief Petty Officer
thats why you bring old parts with you to parts house.safety glasses always good idea when knocking out races.and a brass punch or drift is good to be on the safe side. bearing packer not nessasry. put grease in palm of you hand and use heal of you thumb to pack grease. i can send pics if needed. and the cheapest race installer is the old race,take it to a grinder and grind down outside of eace until it falls out when installed. now you can use this race to drive in new one. ihave used this method foe 30yrs
Lone Duck
Yep!
