Tracker 75 hp Milky discharge from weep hole
Lefty-43
Yesterday I took my 02' Targa out on Lake Michigan & we ran trolling for 5 to 6 hours without any issue. Until we got back to shore & loaded the boat on the trailer. We then noticed a milky discharge coming from a weep hole on the lower unit above the Oil level plug screw.<br /><br />Backing up to the beginning of the day I had loosened & tighted again (without removing any of them)the "Oil level", "Vent" & "Fill" screws.<br /><br />I found when I loosened the level screw it made a sucking sound as if there was a vaccum on it but I didn't think anything of it.<br />When I loosened the "fill" screw I noticed I had clear fresh smelling oil seeping out so I tightened it back down.<br /><br />I have never seen this occur before and I would equate what I saw as oil containated w/water but the "discharge was above all of these ports & seemed to flow for quite some time even today a day later I could see it slowly oozing out of this tiny hole. Any ideas what the heck is going on? :cool:
papasmurf
Re: Tracker 75 hp Milky discharge from weep hole
Need to check the gear oil. If it is clear and full, you are probably noticing unburned fuel and water mix from trolling for that long of a time.
