Towing a 24' pontoon
coresuper
I have a 24' pontoon with a tandem axle trailer with surge brakes. Dry weight of the boat is 2200. Engine is 320. Trailer is about 1200. Will my 2002 f150 supercrew truck pull it okay? It has a 4.6 and is 2 wd. Should I add a transmission cooler? Thanks
Re: Towing a 24' pontoon
Ayuh,.... Welcome Aboard,... What does the Spec sheet on yer truck say it'll pull,..??
ssoper
Max trailer tow weight 6600 lbs
LippCJ7
Your truck will be fine, the tranny cooler cannot hurt though, the hardest part is the braking which the trailer has so you should be fine, well within the capabilities of the F150.
ssoper
Do you have a trailer tow package on the truck? That would include a tranny cooler.
bruceb58
It will tow that easily. You sure the trailer weighs 1200?
kenmyfam
Yes it will. Adding an additional tranny cooler is never a bad idea. Standard ones if fitted are generally minimal at best. Check out some RV forums for further details on that.
Just my humble opinion though.
MH Hawker
Fords are all over the board so you tell me.
F-150 regular cab, short bed 2WD (3.7L V6 and 3.55:1 axle) 5,500
F-150 regular cab, short bed 2WD (3.7L V6 and 3.73:1 axle) 6,000
F-150 regular cab, short bed 4WD (3.7L V6 and 3.73:1 axle) 5,700
F-150 regular cab, long bed 2WD (3.7L V6 and 3.55:1 axle) 5,600
F-150 regular cab, long bed 2WD (3.7L V6 and 3.73:1 axle) 6,100
F-150 regular cab, long bed 4WD (3.7L V6 and 3.73:1 axle) 5,800
F-150 regular cab, short bed 2WD (5.0L V8 and 3.31:1 axle) 7,900
F-150 regular cab, long bed 2WD (5.0L V8 and 3.31:1 axle) 8,400
F-150 regular cab, short bed 2WD (5.0L V8 and 3.55:1 axle) 8,300
F-150 regular cab, short bed 4WD (5.0L V8 and 3.55:1 axle) 8,000
F-150 regular cab, long bed 2WD (5.0L V8 and 3.55:1 axle) 9,800
F-150 regular cab, long bed 4WD (5.0L V8 and 3.55:1 axle) 8,200
F-150 regular cab, long bed 2WD (5.0L V8 and 3.73:1 axle) 10,000
F-150 regular cab, long bed 4WD (5.0L V8 and 3.73:1 axle) 9,700
F-150 regular cab, long bed 2WD (3.5L V6 and 3.15:1 axle) 8,800
F-150 regular cab, long bed 4WD (3.5L V6 and 3.31:1 axle) 8,600
F-150 regular cab, long bed 2WD (3.5L V6 and 3.55:1 axle) 9,800
F-150 regular cab, long bed 4WD (3.5L V6 and 3.55:1 and 3.73:1 axle) 9,800
F-150 regular cab, long bed 2WD (3.5L V6 and 3.73:1 axle) 11,300
F-150 regular cab, long bed 4WD (3.5L V6 and 3.73:1 axle) 11,300
F-150 super cab, short bed 2WD (3.7L V6 and 3.73:1 axle) 5,800
F-150 super cab, short bed 4WD (3.7L V6 and 3.73:1 axle) 5,500
F-150 super cab, short bed 2WD (5.0L V8 and 3.55:1 axle) 8,100
F-150 super cab, short bed 4WD (5.0L V8 and 3.55:1 axle) 7,800
F-150 super cab, short bed 2WD (5.0L V8 and 3.73:1 axle) 9,500
F-150 super cab, short bed 4WD (5.0L V8 and 3.73:1 axle) 9,400
F-150 super cab, long bed 2WD (6.2L V8 and 3.73:1 axle) w/HD package 9,600
F-150 super cab, long bed 4WD (6.2L V8 and 3.73:1 axle) w/HD package 9,300
F-150 super cab, short bed 2WD (3.5L V6 and 3.15:1 axle) 8,600
F-150 super cab, short bed 2WD and 4WD (3.5L V6 and 3.55:1 axle) 9,800
F-150 super cab, short bed 2WD (3.5L V6 and 3.73:1 axle) 11,300
F-150 super cab, short bed 4WD (3.5L V6 and 3.73:1 axle) 9,800
F-150 super cab, long bed 2WD (3.5L V6 and 3.73:1 axle) w/HD package 11,300
F-150 super cab, long bed 4WD (3.5L V6 and 3.73:1 axle) 11,200
F-150 super crew, short bed 2WD (3.7 V6 and 3.73:1 axle) 5,700
F-150 super crew, short bed 2WD (5.0L V8 and 3.55:1 axle) 8,000
F-150 super crew, short bed 4WD (5.0L V8 and 3.55:1 axle) 7,700
F-150 super crew, long bed 2WD (5.0L V8 and 3.55:1 axle) 7,900
F-150 super crew, long bed 4WD (5.0L V8 and 3.55:1 axle) 7,500
F-150 super crew, short bed 2WD (5.0L V8 and 3.73:1 axle) 9,400
F-150 super crew, short bed 4WD (5.0L V8 and 3.73:1 axle) 9,300
F-150 super crew, long bed 2WD (5.0L V8 and 3.73:1 axle) 9,300
F-150 super crew, long bed 4WD (5.0L V8 and 3.73:1 axle) 9,100
F-150 super crew, short bed 2WD (6.2L V8 and 3.73:1 axle) 11,300
F-150 super crew, short bed 4WD (6.2L V8 and 3.73:1 axle) 11,100
F-150 super crew, short bed 2WD (3.5L V6 and 3.15:1 axle) 8,500
F-150 super crew, long bed 4WD (3.5L V6 and 3.15:1 axle) 8,400
F-150 super crew, short bed 4WD (3.5L V6 and 3.31:1 axle) 8,200
F-150 super crew, long bed 4WD (3.5L V6 and 3.31:1 axle) 8,000
F-150 super crew, short bed 2WD (3.5L V6 and 3.55:1 axle) 9,800
F-150 super crew, long bed 2WD (3.5L V6 and 3.55:1 axle) 9,700
F-150 super crew, short bed 4WD (3.5L V6 and 3.55:1 and 3.73:1 axle) 9,700
F-150 super crew, long bed 4WD (3.5L V6 and 3.55:1 and 3.73:1 axle) 9,600
F-150 super crew, short bed 2WD and 4WD (3.5L V6 and 3.73:1 axle) w/16,900 GCWR 11,300
F-150 super crew, long bed 2WD (3.5L V6 and 3.73:1 axle) w/17,000 GCWR 11,300
F-150 super crew, long bed 4WD (3.5L V6 and 3.73:1 axle) w/117,100 GCWR 11,200
coresuper
I don't think so. I can see a small cooler in front of the radiator which I believe is for the power steering.
mla2ofus
Despite the light weight you'll think you're pulling a drag 'chute.
Mike
coresuper
It is not listed here. I have a 4.6L Triton engine
bruceb58
I just pulled a 21' pontoon I just bought with my 1/2T Silverado with a 5.3L. It weighs slightly less than the OP's boat. I could hardly tell it was back there.
coresuper
That's what they told me. It is a Shorelandr and they have beefier rails than most trailers. I believe the rails are 2X6, not 2X4.
bruceb58
That's because all of those are likely 2014 or 2013 models, not 2002 like you have.
Look at the tow ratings for your truck in this link:
2002 Ford F150 Specifications
Assuming your truck didn't come with 3.08 rear gears and/or a manual tranny, your tow rating will be at least 6200.
coresuper
Thanks. My truck has 3.55, so should be good for 6900 lbs.
bruceb58
Ahhh...didn't notice you had a Supercrew in you first post. Actual tow rating is 6,600 or 6900(5th wheel).
oldjeep
Until you hit a crosswind, then it becomes obvious.
bruceb58
I will be towing my pontoon to Big Bear Lake in a couple weeks. When I go through San Bernardino(or San Broke-adino as I call it), I will report back if there is a crosswind.
lncoop
They do catch a lot of wind, but you won't have any issues towing yours behind your F-150.
