torque specs
tfbowen
hi all,anybody have the torque specs on a 1985 85hp force?thanks,tom
I`mNotMe
Re: torque specs
for what specific area?
re: Head (for head gasket replacement), Prop Nut (for prop replacement), intake (for reed leaf / cage) replacement, carb intake (for carb removal and cleaning), etc. etc.
Frank Acampora
Re: torque specs
Head bolts are 225 inch pounds in a spiral pattern working outward from the center two bolts. They should be torqued to final specs in about three steps. With a new gasket re-torque the head bolts after about 1/2 hour running or when you get home for the day.
All 1/4 X 20 bolts are torqued to standard 70 inch pounds.
I never bother with torqueing the prop nut. I just make it one grunt tight.
Carb nuts are 1/2 inch use standard torque for a 5/16 X 18 bolt--I forget what it is right now. Again, I usually just tighten them good and snug.
wickware
Re: torque specs
Search Force torque specs a the advance search at the top and you'll get some choices.
tfbowen
Re: torque specs
it shows a lot but nothing for the 1985 85 hp.
