topside paint and gel coat repair
jkw
hey guys, now that i got the wiring mostly completed on my 1972 sea ray 24 project, my next focus is fixing a few of the gel coat imperfections and painting it. ive done bondo on cars before, but what do i use for marine applications? and is there anything else *cough*cheaper*cough* than marine topside paint that i can use for it? the boat will not be left in the water when not being used.
thanks in advance,
jason
BWT
Re: topside paint and gel coat repair
What is the extent of the cosmetic work?
~BWT
oops!
i agree what is the extent.......a good polish might be the trick......the only reason to paint is that you don't like the color
jkw
Well I thought it was only needing the old cracked paint sanded n repainted, but as I started sanding, I realized it was more like teeny tiny cracks in the gel coat. No real length or depth, n sanding with 80 grits almost eliminates them. So can I just sand n paint like usual without worrying, or does it need something else? Also, there are some little knicks in the gelcoat that I'd like to touch up before painting, is there anything I can use to repair these? Sorry I'm pretty green when it comes to most of this stuff.
Jason
Woodonglass
Honorary Supreme Mariner
The other guys were trying to determine if you wanted to try and buff out the gelcoat. It appears you are going to sand her down and paint her. Lots of options on paint. I'm a fan of "Cheap" too, so I used Pettit Easy Poxy on my hull and Rustoleum Oil Based Acrylic Enamel with Acrylic Enamel Hardener added. Painted the Entire boat, top and bottom with 3 coats of Paint and Primer for $150 bucks. Details are on Page #10 of my thread listed below. I used 3M Premium Marine Filler to fill my gouges, cracks, and deep scratches.
coFLounder
Craigslist usually has good quality paints at greatly reduced prices available. I have saved a small fortune for a few of my friends repainting bottoms of boats the past few years.
OhopJoe
Woodonglass-I see that you are not only a fan of tractor paint but also also of pettit easypoxy. I ordered 2 quarts of that stuff for my Livingston. What sort of primer do you use for it? I was thinking of cheap Rustoleum Enamel Primer or Bull's Eye 1-2-3, but wasn't sure about compatibility with a polyurethane. Of course the staff at lowe's is completly useless. What do you think? Thanks in advance!
Woodonglass
Sorry my mailbox was full. It's empty now. I primed my hull with Rustoleums Bare Metal Primer and painted it with EasyPoxy and I added the acrylic enamel hardener to the easy poxy. It turned out Great. Very Glossy and hard as nails. But now I use Valspars Bare Metal Primer. Check the link in my signature below for my recommendations on paint. R U spraying or rolling.
OhopJoe
Yeah, the mailbox was full, so I had to go public ;) I am rolling. What made you switch to Valspar?
Woodonglass
Switched mainly because Rustoleum techs would not confirm that adding acrylic enamel hardener to their paint would work. I could find NO info that said it would NOT but... Since I could not get confirmation I went to Valspar which clearly states that theirs will. The chemical makeup and formulation of the two paints is almost idententical but I just felt since I was posting on an international forum it would be safer to stay in the same MFG family. I have used em both and honestly can not tell any difference. I guess maybe time will tell. I use Acrylic Paint from Artists Supply stores thinned with acetone to mix with the paint to change the tint to what ever shade I need. That seems to work good to. But Like I always say, I am just a...
