stingray165ss
Thread starter- Joined
- Jun 20, 2012
- 53
Hey guys quick question here, I have a 1996 Chapparal 1830SST with the 4.3L Mercruiser & Alpha 1 Out drive. Currently the boat has a 19P alluminum prop on it, with 3 adults in the boat i can currently get a top speed of 42MPH. The maximum rpm range on the motor i believe is 4400-4800 i feel that i could probably turn higher than that if i were to give it full throttle. The question i have is should i be able to go faster than 42mph with this boat? i was hoping that it would be closer to 50MPH. Also should i go up to a 20P prop? I know that each pitch you go up to drop around 200 RPM. I am not sure how many RPM i can go over the 4800 because i am scared of blowing the motor if i try it.
