too much mix oil
maxxxxam
1997 evinrude when I turn electric power ignition off I hear the vor pump clicking is this normal or has the main power line been hooked up on the wrong side of the ignition? thanks in advance.
cfauvel
if it is a VRO/VRO2 or OMS, it shouldn't click with just the key in the ON/Run position and engine off, nor should it click when you turn it off.
the clicking is a piston that is attached to the fuel pump/air motor. the piston is not electrical in nature.
BUT if the air motor or fuel pump diaphragms are compromised (air leak) then the piston could release numerous times. So I COULD see that as soon as the motor is shut off the piston has a few more strokes left in it as the vacuum is released from the air leak.
not uncommon for air leaks to cause an over-oil condition.
your service manual should have the steps to test the pump for leaks ....remove the pump and use a vacuum pump at the air motor nipple and listen for leaks...it should hold a vacuum...if not you have a leak in the air motor side.
flyingscott
Are you sure it's the pump clicking? What kind of clamps are on oil lines?
V153
On the bright side ya gotta work really hard to over-oil a 2 stroke ...
maxxxxam
believe me when I say it over oiled. after shutdown it had filled the fuel line right to the primer bulb with straight 2 cycle oil. I think I have part of the problem fixed
cfauvel
I suspect the oil piston's o-ring to do bad....please check for gas in the oil reservoir .
if the piston's o-ring is bad and the oil inlet flapper is good, then more oil would be sucked into the fuel mixture....assuming that there are no air leaks in either the air-motor, fuel-pump, fuel lines to VRO or at primer bulb.
maxxxxam
thanks for all the replies but it filled the fuel line to the primer bulb and the mixed reservoir completely full of mix oil while sitting for 4 days. I threw a tantrum and disconnected the oil system and it runs great on my own mix, it may be a pain but at least it starts. It took 5 minutes of idling to get all cylinders firing running on strait gas to clear out the accumulation of oil. It was still smoking but running smooth. I shut it down and started it on a mix. Will try in 2 days and see.
cfauvel
Mod EDIT. solicitation removed
oldboat1
gotta say I don't like the idea of running straight gas under any conditions. There's a sticky or two on converting VROs to premix. Need to plug the oil supply line at the unit, and unplug the harness -- but check.
cfauvel
(update: OldBoat I now see what you were saying...the OP ran straight gas to use up what heavy mix he had in his fuel bowls, probably not a good idea.....I would have used a gallon of premix at maybe 60:1 , to clear up the extra oil )
So if you had any 2 stroke mercury, yamaha, szuki , evrinude , johnson, et al you would pre-mix everyone of them and remove whatever oil mechanism they provided?
what about an e-tec? isn't that direct oil injection to each cylinder ( I don't know)....you'd pre-mix and remove what ever they employed?
flyingscott
When the VRO is over oiling that is usually how they fail. Another reason they will over oil a motor is because of air leaks in the fuel and oil lines. Make sure you plug the oil inlet on the motor otherwise it will put air in the fuel line. And also unplug the harness on the VRO pump itself. You cannot remove oil injection from any Direct injected outboard. Some people prefer to mix their gas oil let them this isn't an oil injection debate.
cfauvel
I'd like to play DR and find out why it over oiled. My gut tells me the oil piston seal is not sealing or the bore that the piston rides in got severely worn thus the piston couldn't seal.
Yep aware of that
interestingly the OMC manual states to only disconnect the oil line when testing the no-oil horn....but I agree that if by-passing completely that you'd want to cap the oil-inlet.
OK fine, always the safer route for sure.
Faztbullet
90% of the time when the fuelline/carbs fill with oil the vent in top of oil cap on oil tank is bad...common problem.
maxxxxam
Since the problem only occurred when shut down for a period of time I wondered if it was possible for the fuel going back to the tank exerting a siphoning effect on the oil drawing it back into the fuel line then when you prime the fuel you end up forcing the oil into the mix chamber and then into the carbs. actually running the strait gas as long as there is enough smoke to obscure the back of the boat, there's enough oil. I was a faller for 30 years ran and worked on many power saws, this is just a 6 cylinder power saw, 2 cycles are very forgiving and for the most part simple. vor is too fancy. My opinion only.
