(update: OldBoat I now see what you were saying...the OP ran straight gas to use up what heavy mix he had in his fuel bowls, probably not a good idea.....I would have used a gallon of premix at maybe 60:1 , to clear up the extra oil )gotta say I don't like the idea of running straight gas under any conditions. There's a sticky or two on converting VROs to premix. Need to plug the oil supply line at the unit, and unplug the harness -- but check.
So if you had any 2 stroke mercury, yamaha, szuki , evrinude , johnson, et al you would pre-mix everyone of them and remove whatever oil mechanism they provided?
what about an e-tec? isn't that direct oil injection to each cylinder ( I don't know)....you'd pre-mix and remove what ever they employed?
When the VRO is over oiling that is usually how they fail.
Yep aware of thatAnother reason they will over oil a motor is because of air leaks in the fuel and oil lines.
interestingly the OMC manual states to only disconnect the oil line when testing the no-oil horn....but I agree that if by-passing completely that you'd want to cap the oil-inlet.Make sure you plug the oil inlet on the motor otherwise it will put air in the fuel line.
OK fine, always the safer route for sure.Some people prefer to mix their gas oil let them this isn't an oil injection debate.
ahhh...another one to put into the memory banks90% of the time when the fuelline/carbs fill with oil the vent in top of oil cap on oil tank is bad...common problem.
