Too Far Gone ?
SgtMaj
Re: Too Far Gone ?
WOW !! Lots of good ideas here. First I want to say that the guy bought the boat from me, and did a compression test onthe engine prior to running it in water. Turns out it needed a head gasket. I gave him all of the parts, including a reman head and he was to do the labor. It looks like the trailer they lived in had a fire a few years ago, and you never see anyone around the house. I am going to call the twsp, and find out what the storry is. I am sure that they would want it removed. How much work is involved with that windshield mess ? Yhat is all that scares me. Thanks again, Dave
Well, if TD is right and there is a gap between the windshield, that could be a big problem (not because of the windshield, but because it indicates a much larger problem with the hull). But... from the angles of the photos, I can't really say that I can see a gap... the ceter piece may just be smashed in a bit... if that's the case, that's incredibly easy to fix, and cheap, too. You can get a new curved windshield for something like $40-$60/piece from a plexiglass manufacturer, and non-curved pieces you can have cut to size for even less. The metal frame is just bent sheet metal, which any metal shop can do for next to nothing as well.
One thing though... and trust me on this... make SURE this is going to be worth it. It may be cheaper and easier to take some of the money you would have invested into restoring this boat, and getting a better boat from the get-go. I got an older boat in poor condition due to the low initial cost of it (and ignorance at the time)... and I can say without a doubt that was a BAD decision. I'll end up spending 5 times as much to restore this boat than one in the condition I'm restoring it to would have cost... and that's just the money end of it... then there's the backbreaking work involved, and the time it'll take to get it out on the water. The boating season you'll miss because it wasn't ready. On the plus side, you'll learn more than you ever wanted to about the hardware and maintanence. It's just too bad it'll cost you more than a 2 year degree for a marine maintanence technician.
PS - listen to TD. He really knows his stuff, and when he says it's not worth it, odds are it's not worth it even when you factor in the pride and sense of accomplishment from having done it yourself.
Nandy
Re: Too Far Gone ?
After hearing about the motor all I can say is run the other way, save your money for a running boat. You will spend a lot of time working on this boat, dont know it the motor will work and if does you are looking at more than 1k to get the hull fix. You can get a runing boat of Craiglist for half that.
BUT, it you decide to go for it, we will be here to help...
azlakes
Re: Too Far Gone ?
It can be restored and you can make it better then new,,,,, NO PAYMENTS
"http://web.mac.com/tanyard/Site_6/before_pic2.html"[/url]
"http://web.mac.com/tanyard/Site_6/aug_10.html#15[/url]
"www.bigwoodenboat.com[/url"[/QUOTE...nsidering financing an Ocean Liner. Nice job!
Re: Too Far Gone ?
Its like a car in a way ,when you can replace it cheaper than restore it you junk it. If the boat were a rare wooden hull runabout oh yes its worth it, just like an old mustang GT or Chevelle SS........compared to an old 4 door tempo or chevette,see what I mean. And dont forget messin with fiberglass can be a hazard and its not easy the first time.When a boat has bad wood rot inside the fiberglass its sorta like bone cancer,,
SgtMaj
Re: Too Far Gone ?
I'm tryin to restore my '66 woodson (fiberglass), but she's resisting... :D
Actually, I'll probably feel a lot better about it once I get the new deck in, which I'm going to start on this weekend, maybe. That is, if I can finish up those gunwales I already started on.
