Tohatsu 9.9D2 after wrong modification?
Status
Not open for further replies.
Szmaja
Good morning dear forum. I will be grateful for dispelling my doubts.
I bought a Tohatsu 9.9D2 from 2002, with throttle cam 362-63718-0 installed. Thanks from reading the forum I already know that this is the wrong cam version for this engine (the correct one is 3M3-63718-0). Nevertheless, the engine is running perfectly fine: it has power, starts up quickly and burns normal amounts of fuel.
Timimg was set at 25 °
The butterfly could fly in 180 ° ...
Please confirm or correct me if Im wrong, whether this modification needs to be fixed?
Engine will work better with newer cam 3M3-63718-0?
pvanv
3M3637180M is the 15/18 throttle cam, so you got a free upgrade.
Szmaja
Good morning, sorry for my language above I try to write that my Tohatsu 9.9D2 has throttle cam nr 362-63718-0 installed (You can see it on attached photo).
This modification was made corectly?
Thank You for help.
pvanv
Apparently. Many upgrade the old 9.9s to 15s by installing that cam.
Szmaja
Interesting, what is a difrence when they work. The shape in midle range of 362-63718-0 this steep profile indicates that the engine can pick up speed faster. It could give more dynamic haracteristic in midle range. Thanks for help. Best regards,
MattFL
Master Chief Petty Officer
I would guess the original cam probably doesn't open the carburetor all the way.
Szmaja
I wonder what is a difrence without cams: 3M3-63718-0M and 362-63718-0. Can they give different characteristics during acceleration?
pvanv
The 3M3 is also used with the bigger carb to get 18 hp.
Argypa
Does anyone knows the correct position for the timing and if it is easy a photo of the timing.
Status
