tohatsu 40 hp starter problem
spartan89764
i have a 2008 40 hp tohatsu with elelctric start. the motor starts and runs just fine. but while it is running it tries to fire the starter again. any suggestions on what to do? there are no dealers or licensed marine mechanics were i live. remote island in alaska. any suggestions would be greatly app.
pvanv
Re: tohatsu 40 hp starter problem
You probably have a wiring problem that is triggering the starter. I take it this is a TLDI motor? Is this with an RC box? If so, you may have a flaky key switch. What is the precise model/serial?
spartan89764
the model number is md40b 3t4. i will have to get back to you on the serial number.
TOHATSU GURU
You have a TLDI model. But, the problem would be the same regardless of what you have. Crossed wire, incorrect wiring or ignition switch.
pvanv
I would suggest you get a factory service manual, available from any dealer (including me) to review the wiring diagram. You can order Part# 003-21050-2 $27.58.
