TOHATSU GURU
- Jul 22, 2004
- 6,164
Re: Tohatsu 2004 40hp question?
That begs the question...Why didn't you address it through your local dealer while in warranty? I'm not picking at you, I just hate to hear that you had a problem and didn't let your local Wizard spend Tohatsu's Yen to figure it out and correct it. The jets are good up to 5000 feet so that's not the problem. You could have a piece of trash in there from the day you have had it, but that's unlikely too. There is a rough spot in the RPM around 1650 RPM when the engine transitions from the Slow to Main jet. But, that only occurs within a 50 RPM powerband. The engine is not running lean if you are getting fouled plugs. Again, look at your carb settings and see if you are too rich, see if they are in sync, check your fuel pump diaghrams, check for a leak in the fuel lines, check your reeds. If all of those are okay then check all of your ignition components. If you still can't find the problem run it to a dealer. (I'd do that first, but if you want to spend the time yourself)
The idea with troubleshooting an engine is to start at what is most commonly wrong and work outward from there. There are a lot of things that can be wrong, but almost never are. If you waste your time starting at the wrong end of the problem chain you can spend an awful lot of time and money to find out it was a piece of casting hung up in the carb. That's not to say that you couldn't have a rare problem, but we call them RARE for a reason. Look at it this way: If you go to the doctor for a runny nose does she stick her finger up to check your prostate? No, she tells you to drink lots of beer and take lots of naps. We do the same in mechanics. If your engine is running rough we tell you it's probably your carburetors, because that is what it usually is. Always keep it simple and save the oddball and bizzare possibilites for last.
