Tohatsu 18hp M18C 350A Carburetor Float Setting
SeaKaye12
Hello all. This is one of the older M18C (SN 22229) with the "free-floating" float. The float has no tab connected to it. You can see the illustration for clarity.
Is there a procedure for setting the float level (height?) If so....can you tell me what the spec is?
Thanks so much. My engine runs very well at mid to wide-open but seems to be rich (4-stroking) at above idle to mid. Advance the throttle past that and it clears and runs great.
Thank You.
