Originally posted by oneoldude:<br />
2# per the additional weight would be 24#.
That's true. That stuff is calculated to be 2# sq.ft. under labratory like conditions. It usually comes out heavier. I'd definitly use the 2# stuff. The strength of it is incredible, and the 4# would be overkill on top of overkill, and a extra 24-odd pounds wouldn't be a big deal, but it would about double your cost for the foam.<br /><br />Raising up the stringers is the way to do it. Most folks wouldn't think of that. Its a great project, but I wonder if you're making alot of extra work & expense for yourself by raising the floor. <br /><br />To need a self bailing feature for the inside of the hull,,,, If you're not getting some horendous amount of water coming in, I wonder if it isn't a solution for a problem that really doesn't exist. <br /><br />Something that just dawned on me is if you loaded the boat sometime with a couple extra passengers or gear, and it ran a little deeper-- water might actually come in through the scuppers if you were in a 'following sea' or got caught out as a storm can in on ya.<br /><br />A inch or so of water sloshing around isn't a big deal, and it'd run right back out,,,,, but it is a little un-nerving to those who aren't used to seeing much water moving around inside a boat.<br /><br />That is one heck of a boat. At this stage of the game, if you're working towards making it the ultimate fishing machine, you might also consider ripping out all the interior.<br /><br />That would open up more options as far as making a center console driver's station and casting platforms both 'fore & aft.<br /><br />Going from there- you could make it lighter and stronger than it was the day it left the factory, and it'd be light enough to run on wet grass.
