Dee Rambin
Thread starter- Joined
- Jul 16, 2002
- 13
I think I figured out why they say to disconnect the battery if the boat is to be stored for a long period of time...<br /><br />I recently purchased a basstracker with 1981 model Mercury 50hp that had been sitting for approximately 6 years, with the old battery still connected. I noticed the wires coming out of the rectifier were badley corroded. I removed the contacts from the rectifier and the wires basically came apart in my hand. The "green monster" has crept from the rectifier all the way up under the flywheel to where they connect to the stator. <br /><br />I am in the process of finding a puller to remove the flywheel to see what else is destroyed. <br /><br />Do the wires go directly to the stator or is it possible to replace the wires without replacing the entire stator assembly? I would like to have the parts on hand when the flywheel is removed.<br /><br />Also, is there someone that is familiar with a flywheel puller for this model motor? Is this something that can be "fabbed" or do I have to shell out the money for the real thing?<br /><br />Thanks all...
