Timing please
southern180
I have early a 4.3 with the 177 casting block and two piece main seal. I have a book that says time 8 deg BTDC and another says 10 deg BTDC then there is the book that says set to zero then time with light. I would like someone to send a link or explanation the procedure from setting the number one to top dead center and go from there. The engine has the module that does the timing bolted to the riser.
Thanks
Re: Timing please
I have a book that says,... and another says,... then there is the book that says
Ayuh,.... Welcome Aboard,...
Just What books have you been Reading,..??
And What are you working on,...Year,..?? Make,..??
