Timing on 88 Force 125hp
Bry21317
I have an 88 Force 125, that I am trying to get the timing set on. It was running good, but I decided to recheck the timing, when I put it back together after a Carb rebuild, and added Boyesen reeds to the engine. <br /><br />When I hooked up the timing light, here is what happened. The timing mark on the fly wheel (28 degrees) was over to the left (when inside the boat looking back at the engine) of the timing pointer by about 2 inches when looking at the timing light. Now, I think this could have been my fault, because I forgot to put it in gear, and only had it running in idle when I tried this. So I am hoping that this was the problem, since the timing advance of being put in gear didn't move it to the correct timing. <br /><br />I have'nt had a chance to try timing it again. Cause I don't want to **** off the neighbors at night, when its dark enough to see the timing light.<br /><br />Could this have been my problem? Or is it possible that I slipped the flywheel somehow?<br /><br />Thanks,<br />Bryan Cox
12Footer
Re: Timing on 88 Force 125hp
Once the timing is set at idle, it should track just fine...Providing, you haven't changed the advance linkage adjustments. If you have, you will have to take her out with a competant 1st mate, and have them pilot while you adjust a WOT. Test tanks with test props just aren't the same.<br />At idle, in gear, it should hit 28degrees before the TDC mark for Prestolite, 32degrees BTDC on Thunderbolt and CDM ignitions.
Bry21317
How do I tell which Ignition I have? I have the Blue boxes, with the spark plug wires coming out of them.<br /><br />Thanks,<br />Bryan
12Footer
The blue unit with color-cordinated coils is Prestolite.
