Timing Info Needed for '85 140
Grub54891
Re: Timing Info Needed for '85 140
You will want to get one of these to get at the bolt easier,
Jacalore
Thanks, Brian, but the manuals stop at 1984!
Ayuh,.... Yer motor is an '85,..??
An '84 manual is still better than nothin',...
It ain't like the 3.0l changed much over the years,...
Jacalore
Not sure which MerCruiser Service Manual I'm looking for #8 or #10?
Don S
Not sure what you looked at, but the manual in Brian's link has all of Mercruisers manuals, through 2008.
You also have an 85 boat, but that doesn't mean your engine is an 85, could easily be an 84. Very common in boats. Post a serial number for your engine, and we will see if you need manual #3 or 10.
Jacalore
There is a little horizontal slide under the images for Service Manual #1 #2 #3 and #4 it goes all the way to service manual #42
How did I miss that! Thank you.
Where can I find one? What is this tool called? Thnx!
Ayuh,.... A Distributor lock bolt wrench,.... I think even Harbor Fright carries 'em,...
