redjmp
- Mar 16, 2005
- 536
Re: Timing and Sync of Merc Inlines (to 1988)
Great info!<br />I just want to verify this is the correct procedure with an '86 115.<br />The decal says 6*ATDC running and 18*BTDC at cranking speed (400 RPM) which is suppossed to equate to 21* @ 5500 rpm.<br />Now from what I understand, the first little bit of throttle arm travel only advances the spark and does not engage the carburetors' butterfly valve. Is this correct?<br />However on this motor, I need to back the low idle screw all the way out until the rod that connects to the armature under the flywheel (which is connected at the top end of the throttle arm) makes contact with the front cowling support bracket and can go no further but at this point I can only get 5* ATDC.Assuming this is close enough(I am only using cranking speed here)<br />Should I then adjust the caburetor cam to make contact at this point?<br />Doing so will mean that the carbs will start opening with any movement of the throttle and therefore idle rpm will not just be a function of spark advance.<br />Thanks for your valuable input Clams.
