Folks be very careful with Horse Power ratings on so many electrical tools these days, especially on Air Compressors! If you seriously understand HP which is: A Unit of power, equal to 746 watts (joules per second) or 550.22 foot-pounds per second (fps), slightly higher than mechanical horsepower (745.7 joules per second or 550 foot-pounds per second) you will see how it gets used incorrectly! But the manufacturers play around with their HP claims and therefore make it look like theirs is better then the exact same everything from another vendor so often. So basically forget about HP ratings, they seriously are meaningless with compressors. If fact some places even state equivalent HP trying to skate on their claims. Sear is notorious for that!
And another item to be questioned too is amps! If one vendor says their motor uses 10 amps and another states their uses 12 amp, it honestly doesn't mean anything. And the reason why is, any poorly designed motor (and there are tons of them available) will read and use higher number of amps without seriously outputting any difference in their capability. So amps is another misnomer that the manufactures are using to promote their products knowing the general public always thinks more is better...not so! Better quality copper motor windings with quality materials, bearings and their actual designs will always use less current then some haphazardly assembled junk. Everything requires more current if it isn't of quality construction...even things as simple as bearings and alloyed metal windings to save a penny! Even a finely turned and balanced armature can work better will less amps!
Now if you really want to do side by side comparison, use the CFMs at 90psi and hope their numbers are truthful. A compressor that can deliver X number of CFMs continuously at a set pressure is the only real spec you can compare. Everything else is pure horse dodo. So for a better compressor, check out two items, the ability to supply a certain CFM at 90 psi AND the life expediency of the actual air pump. Both are listed for every air compression I've ever seen. That IS just my knowledge of this issue after reading too much about compressors over the years... JMHO!
