VisionIsle
- Feb 10, 2006
- 98
Volvo AQ240A/ 280 outdrive
After putting my boat in reverse and looking over the transom I have noticed the outdrive does not lock down, Even though the light goes out on the dash when fully lowered. In fact the outdrive goes up and down without a problem but does not lock when in reverse.
What I have found is that when I removed the electro-mechanical box about a 1/2" of the top of the "upper part" is broken off.
I am trying to attach a photo
It looks as if the top portion of this "upper part" actually holds the vise rod. Can I just remove this upper part and replace it? Is this the reason the outdrive will not lock? How is it still working with this part broken. Oh and can I do this with the boat in the water?
Thanks,
Carden
Thanks,
Carden
