Tilt Tubes
pequa1
I have a Yamaha C-90 but the real question is whether the rod should be stored all the way inside the tilt tube when the boat is not in use (with the wheel hard over) or doesn't it really make a difference ? I lubed it, but maybe not enough. I ask because I have had to either replace the steering cable or had the steering freed up professionally abt most about every four years. Not interested in hydraulic system at this point, so please don't suggest, lol.
alldodge
Re: Tilt Tubes
Since your from Long Island I would say your biggest issue is salt. Placement of the steering rod in or out will make little difference. The more often you add lube and protection the longer it will last. Just washing the rod out well help, but once washed out you need to relube
99yam40
Re: Tilt Tubes
If you store with rod all the way in you cannot hit it to break it loose when it rusts and locks up.
There are nuts with o rings you can replace the original on with that helps seal water out and keeps the lub in.
even has grease sert to pump grease into it.
I had one on my old Johnson, but do not know if it would fit on the Yamaha
pequa1
Re: Tilt Tubes
Thanks for the replies.
Yes, I have that nut with the fitting on it to insert a lightweight oil. But 99yam40, you are right about not be able to wack it
free if I leave the rod all the way in, as I have gotten an extra season out of it by heating with a hair dryer and wacking the h. out of it.
Unable to wash the tilt tube out as the engine has to be removed when the steering cable needs replacement. (small boat, tight transom space)
99yam40
Re: Tilt Tubes
I have run a Wire pipe brush through the tube on a 1/2" drill motor to clean out the rust and build up, but have to get cable out 1st
