porkys2024
Thread starter- Joined
- Aug 24, 2024
- 11
can you help me figure out my wiring harness prob. I have a 1999 fisher 25 ft pontoon with a diff, newer model engine a 2004, 3.0 mercruiser stern drive with what looks like a 9 pin harness, lot of the engine compartment harness has been cut and cobbled and somewhat diff color wires attached. the block number is 1M12054RP and i think it is OLO97000 THRU OW301999, Eng ser number is OW 001-466.. they are 8 pins in the male plug but 9 holes one looks missing, Blu, Red, Grey, Black, Brown/white stripe, Tan/Red stripe, tan and purple but i counted around 20 wires running up to dash board. side note, the female connector on harness has light blue wire and male has darker blue wire other then that all the same? I hope you can steer me in right direction. now what im needing is help with the trim sending unit on starboard side of stern and the tilt/trim gauge on the dash. ive done everything in the book to get it set right and working, now the port side puck for trim/limit works fine i have it set at 20 3/4 in rise.. but my gauge for tilt/trim can not get it to work.. its either up or down.. ive bought new gauge and pucks and still not workin.. I did take a the old gauge from dash and jumper-ed it to the two wires coming out of sending unit puck on side of stern unit and turned the shaft by hand and it works perfect up and down but put it back in gauge cluster and try it with the tilt/trim up down button on control lever and nothing!! im about to burn it! any suggestions? Thank you for your time. I do no that my book says the brown with white strip is the gauge sending wire and i have checked continuity between brown/w wire and its got continuity, if that helps and I assume the other is just ground? one last thing my unit works perfect both with just up and down button on the gear box also the trailer lift works as suppose to..
