On a Rude 1984 90 horse. I had to use the release screw to lock it up today. Any thoughts?? Thanks!!
M mrcool Petty Officer 2nd Class Thread starter Joined Oct 7, 2008 Messages 113 Aug 22, 2010 #1 On a Rude 1984 90 horse. I had to use the release screw to lock it up today. Any thoughts?? Thanks!!
oldcatamount Lieutenant Commander Joined Apr 4, 2010 Messages 1,740 Aug 23, 2010 #2 Re: Tilt/trim go's down but not up? can you tell if there is power going to the pump when you try to put the motor up? It may be a bad rocker switch.
M mrcool Petty Officer 2nd Class Thread starter Joined Oct 7, 2008 Messages 113 Aug 23, 2010 #3 Re: Tilt/trim go's down but not up? oldcatamount said: can you tell if there is power going to the pump when you try to put the motor up? It may be a bad rocker switch. Click to expand... No not really, It makes the pump whirring sound going down, but nothing coming up, the rocker switch DOES stick and you have to be careful or the switch might stay in the up or down position, that could have happened?
oldcatamount Lieutenant Commander Joined Apr 4, 2010 Messages 1,740 Aug 23, 2010 #4 Re: Tilt/trim go's down but not up? I'm not sure if you can just take the switch out and clean/oil it or not. Probably needs replacing. However, I,m just guessing here.
S seahorse5 Rear Admiral Joined Jan 24, 2002 Messages 4,698 Aug 23, 2010 #5 Re: Tilt/trim go's down but not up? Have you swapped the 2 relays to see if it now goes up but not down?
