tilt motor
docspenc
I'm not having any luck figuring out how to remove my tilt motor on my 1977 sea ray. it's a 352 ford and a 235 omc. do'es it come off from the outside or inside the boat. The motor is on the inside but I don't see any bolts to remove? (tilt goes down good but has a very hard time going up.... most of the time it won't even go up.
southkogs
Re: tilt motor
Should be two bolts (one on either side) running the length of the motor into the intermediate housing. Unplug, reverse those out and it should fall right out.
Do you have a manual for it?
docspenc
Re: tilt motor
Are you talking about the two nuts on the back of the tilt motor?
docspenc
Re: tilt motor
So here are some of the ones I found on ebay. Looks like they bolt on from the front... I can't see any such bolts .
docspenc
Re: tilt motor
navycowboy44
Re: tilt motor
looks like the same motor i have. yes those are the bolts. theyre a pain in the butt to get to
docspenc
Re: tilt motor
So if those are the bolts to take out, I can get to them from inside the boat. The tilt motor is just under the back motor mount. They must be long enough to go though the tilt motor and into the ? Thanks for all your help. I'll try and get them out tommarow:cool:
docspenc
Re: tilt motor
Can you tell me the part number for a 1977 235 omc tilt motor?
navycowboy44
Re: tilt motor
I wish i would have saw this post before i went and worked on my boat lol. my boats not at my house and the tilt motor is sitting in the boat. call up your local marina and see if they can look one up if not i should be able to get a part number to you by tomm night
southkogs
Re: tilt motor
I think it's a Prestolite ETK4102, however before you hunt down a new one ... take your motor to a local parts store and see if they can rebuild it. It'll be about half the cost of a replacement and I was utterly amazed that my trim motor could be "resurrected."
docspenc
Re: tilt motor
The part # is 382138 Thank's for your help. Maybe this noumber will help someone
navycowboy44
Re: tilt motor
yup thats the number. look on ebay before you go to a marina. i found one for $60 instead of $160
