Re: tilt and trim
Time to break out the ohm meter and see where the connection is bad. Could be in the plug, or anywhere along the wires, or the switch itself. Since neither up or down works from the remote control, it could be the plug, the common, or the switch. Disconnecting at the plug and checking continuity from the remote control switch would be a logical place to start. If continuity does not check out at the plug, I would then check the switch. This will help determine if it's wiring or the switch. If that checks out, then it could be the contacts in the plug, or the wiring from the plug to the relays. In this case, looking at the common first would be the place to start.
This diagram may help:
http://www.maxrules.com/graphics/omc/wiring/TnTwiring.gif
PS. When did it work last?
