triple m outfitters
Thread starter- Joined
- Jun 18, 2015
- 21
I have a 50hp MD 50 Tohatsu (jet). Intermittently while tilting or trimming the engine up (hitting the switch up) the engine will continue going up even after I've let off the switch. This morning while coming into shore I tilted the engine up just a few inches to avoid scraping the engine, the motor went to full tilt even though I only hit the switch to rise it a few inches. The tilt continued even with the the key off. Recently I changed both up and down solenoids but never changed the tilt trim switch. How do you check this switch? Is the switch easy to change? What else could this problem be?
