ticking nosie
buggiedad_67
Ok need some help, i have a 84, 120 hp. i have a ticking nosie like a lifter, i checked here and found that the flapper may make the same nosie. so i removed it, the engine was rebuilt before i got it and had three bent push rods, so i replaced all lifters, push rods, and rockers, still have the nosie, i have rpm set at 950. if i up the rpm tp 1100 it goes away, any help, thanks richard
cbavier
Re: ticking nosie
Could be and hope it is, just water passing through the manifold. It makes a little tingling or ticking noise.
Welcome to I Boats
Maclin
Re: ticking nosie
On some engines their mechanical fuel pump can make a ticking noise that can sound a lot like a lifter.
qaztwo
Re: ticking nosie
Why were the push rods bent? Is the noise coming from the valve cover? whats the oil pressure?
Re: ticking nosie
Ayuh,.....
And,... With the Idle at 950rpms,....
You're going to Destroy your Outdrive..........
djvan
Re: ticking nosie
Did you get a look at the cam gears? My gears were getting bad and started with a ticking. One gear on mine was aluminum with nylon teeth.
DougV>
wire knot
Re: ticking nosie
At the risk of sounding stupid......never mind one of my fote's.
I had this problem after adjusting the valves one time.
Turned out I had installed the valve cover upside down.
Sure quiets down if the lifters don't hit the cover.
You're probably not that stupid.
Get a stethiscope(sp) and track it down.
A long screwdriver works as a substitute
WK
Re: ticking nosie
How does one install a valve cover upside down? Rotated 180 degrees maybe -- but upside down? :)
wire knot
Re: ticking nosie
OK...... so even my explaination sounded stupid...LOL
I see what you mean.... not even I
could put one in upside down.
Boy......you sure got me on that one.
You silvertip DEVIL
WK
buggiedad_67
Re: ticking nosie
ok no the cover is on right, the push rods was bent because it had colasped lifters, and mushroomed the valve stems, removed head replaced valves, lifters and rockers arms. used stehascope and no nosie comeing from cam cover, valve cover or valve cover, and all sounds good comeing out of oil pan, oil pressure holds a firm 40lbs, as far as rpm goes what is it supposed to be???????? it has the same sound a rocker makes when not adjusted right, but i have run the valves for times( sorry about spelling i know thats what spell check is for)
buggiedad_67
Re: ticking nosie
i guess i should also say that it is a clear and sharp sound not like a low end knock or rod knock, i build vws and have a couple of show cars, been doing this awhile, i know i dont know it all and when it comes to boats will i am here looking to learn.
Re: ticking nosie
Ayuh,....
Did anybody mention the Fuelpump,...??.......
Those little 4 bangers never were the Quietest motors around,....
You might be chasing a Ghost.......
And,....
What about the Idle rpms,.?.?..?. You're going to Trash your outdrive at 950rpms.........
buggiedad_67
Re: ticking nosie
i unstand that i will trash it. si what do i need to set it at, yes i check the fuel pump, even replaced it with one off a friend boat and it is still there, the mortor runs great, it is in a 16 ft glasstrem 152 tempest, pulls two tubes skier wakeborad and knee boards, with two in boat, i love the boat, but i think i forgot to say it has been bored 30 over, and way what do i set the rpms at, and yes i maybe chaseing a ghost
96lt4c4
Re: ticking nosie
If this is a flat tappet cam, which I am pretty sure it is, you should never install a new set of lifters on an old cam that has already been broke in. The old lifters break in with the cam. Ask me how I know, I wiped out a cam and a new set of lifters doing this. Pull you cover back off and check for any loose valves.
I beleive idle RPM should be around 500-550
buggiedad_67
Re: ticking nosie
thank you bond-0 yes that will help i am sure, and yes i did note that the fuel pump was mentioned, yes i do know it is not a good idea to install new lifters on a old cam, and i did run the adjusted the lifters four more times, the idle setting i was useing was because that was were it was at when i got the boat, and since most car engines that i have worked on set ariund that same i used it thinking it was ok, i am sure glade that i joind this forum and got that part fixed, thanks.
cbavier
Re: ticking nosie
What does your Owners manual say the Idle Rpm should be set at? 950 sounds high. My 4.3 185 HP Idle is suppose to be at 700 RPM. If it's too high (950) it's gonna clunk every time you put it in gear and eventually your going to be replacing the U Joints, if it's an I/O as I assume. You never did say I/O.
By the way WELCOME Aboard!
buggiedad_67
Re: ticking nosie
thanks i didnt have a manuel for it but bond-o sent me a link and it sets at around 700 to 750 somewhere in there i have it set at 750 right now by the dash. and it shifts better, huh go figure, the nosie is still there so i have decided to run the dog mess out of it and see what happens, it had this nosie in it when we got it thats how i found out some of the things but it seems no matter what i do to stop it it wont go away
Coors
Re: ticking nosie
Why did the lifters collapse? Oil pressure? how many?
