Thunderbolt V question
Pmt133
So this stems from a comment @muc Had made in another thread a few days ago. My 4.3 has a thunderbolt V setup on it with the black denso module. System has been more or less fine aside from that one issue I had where I was getting a backfire through the intake, documented here. Haven't had that issue crop up since last reported in that thread which is good, but curiosity got the better of me this week.
My distributor still has the 2 wire pickup, the one without the extra ground going to the back of the head. I didn't know this was a thing. My question is two parts. Firstly, should I be swapping to the updated pickup? And second, do you all suppose that could have been a contributor to my issues? I don't know much about what the problems were with the various sensors. I can say I've had pickups cause all sorts of issues on HEI setups similar to what I experienced. But it never came and went as intermittently as this, it was usually a consistent drop in spark.
Thanks all.
Scott06
I would swap it out given the comments. Get a cap and rotor as they have to come off and often the rotor doesnt want to come off in one piece
Pmt133
I always have a spare set. Coincidentally I've not had an issue with the rotor on this engine.
Scott06
I didn't have an issue with my rotor , preventatively changed it as the cap had green crusties, had to chisel the rotor off. I dont think I was a one off as they put loctite on them. bottom line likely to change the sensor you will waste a rotor
Lou C
Why did Merc put loctite on a rotor? Never had problems with rotors getting loose and had several vehicles & now the boat with old style points systems.
Scott06
Cause it made someone feel good at some point, pretty sure it is in the manual. They way the rotor went on with out it , its not coming off.
Pmt133
Didn't know about the loctite. Just press it on normally.
Lou C
Had air cooled VWs (Bosch distributor) Chevrolets (Delco), Fords (Motorcraft) Honda (Hitachi) and the old boat (Prestolite) never heard of this. Crazy idea!
