Thru hull seacock leak
Gradysea200
Easier to replace the seacock or just fill it. Dont plan on using the live wells so it's pretty much useless. Just looking for the easiest way out. Boat is a GW seafarer if that makes a difference, any input would be well appreciated. Good day mates.
alldodge
I would probably remove the thru hull, cut hole a bit larger to insure water has not gotten into hull. Then cut core plug, epoxy back in. Cut another piece to cover over plug hole and part of hull and epoxy it in. Then epoxy paint the inside and finish bottom and re-gelcoat
Ayuh,..... If ya got the materials layin' 'round, you could patch/ plug it,....
If ya gotta buy either the materials, or the valve, I'd probably go with the less expensive option,.....
dingbat
Thru hulls and seacock are two different things. Are you talking about the seacock for the live well pump? Running a washdown?
