seattle scott
- Nov 1, 2011
- 113
the idle stop on the tower shaft doesn't return to "stopped" position so the idle speed is very high ( I don't have a tach) in neutral. I can push the thottle linkage back to idle by hand, but when the control box level is moved to forward, the thottle engages first so the motor jumps into gear with a big clunk and the boat takes off at jogging speed.
Frank posted an explanation http://forums.iboats.com/showthread.php?t=502943 and said Note how the spring loaded center section is pulled out about 1/4 inch in neutral. This allows the engine to shift into gear before the throttle starts to open. Can anyone add to this explanation/description so I sort this out or what I am missing or don't understand as to how to adjust the gear and throttle cables at the engine. I will get some photos up tomorrow.
