Once it starts, idles fine. It depends on how long it is off 5-10 minutes it starts fine. Much longer, needs to be advanced again to start.Being a GIPEFS it would be EFI using TBI.
Your symptoms would lean me toward the IAC and/or or the IAC path way is clogging up and dirty.
Wants the motor starts does it idle ok?
After it has started once does the throttle need to be opened some each time to start or is it no longer needs that?
