Thread Merger...Speedometer to guage rapid movent out of th...
Here is a link to a related speedometer question. But first a comment on the theory and operation of the boat speedometer. <br />"the speedo works as a "bourdon tube" type instrument<br />I/E a coiled tube usually of brass.<br />as pressure of any kind is applied it tries to "straighten"<br />the bottom of the tube is hooked to a chain<br />and pulls on usually a chain <br />that is hooked to a gear ..than the gear rotates...<br />that gear is moving the "pointer" of the instrument that is is attached to.<br />"hence" the pressure applied to the "bourden tube " reflects ......what ever it is calibrated to ..speed , and or pressure...<br />In a short :::::<br />the water pressure that the "pitot tube see's "<br />by being placed in water usually on the transom,just barely in the water at speed .<br />that pressure is then transfered to the speedometer by the usually small plastic hose. <br />the pitot tube is not the hose ..<br />It is the device that is in the water , airstream if you are in a airplane.<br />Now just how was that watch made?? or did you just ask for the time ???<br />lol "<br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=1;t=012626#000005 <br />RE: Powercat udate, Boat Restoration; Mark 78 backfiring, Mercury outboard...troubles.<br />Hey Baylor, I think you either need a little more time or a little more JD. Was that number 7, or Black Label? Remember JD and JB do not mix. ;) :) <br />Dunaruna: Did the email you sent bounce. Congrats of the cricket sitcho.
Dunaruna
Re: Thread Merger...Speedometer to guage rapid movent out of th...
I'm lost again. Have you got a speedo problem?<br /><br />No , the e-mail didn't bounce.<br /><br />I prefer Glenfiddic.k but black label will do if I must :) .<br /><br />Re: Backfiring, did you check the spark plug leads?<br /><br />Your explaination of the workings of a speedo is very good, it is, basically, a pressure guage. Is that a C&P?<br /><br />Aldo
You think your confused. Walk a mile in my boots. Are you currently embroiled in the cricket matches? If your message did not bounce back it is still floating around in cyberspace. It is imperative that you follow the links and become familiar with the conglomerate threads. Yes, I do have a Speedometer Problem. No, I do not wear Speedos.<br />Hey Baylor is the one with the Jack Daniels, Mine is Makers Mark. Where can I find a bottle of your call? <br />The speedometer tube has been severed and I am trying to determine where to the output is on the LU. <br />Nice to know you are still looking after me.<br />Have you been informed as to the complete results of the Shakedown cruise? We are changing the name of the boat from the Phoenix Cruiser to Micahs' Prize. (long story) Keep us upto date on the cricket thing.
heybaylor
Dont think you have a "ouput on that Mark 78"<br />You will have to attach the pitot ( called a pickup in boat stores) to your transom..<br />If your engine is a counterclockwise prop..<br />than put it on the left side as close to center as possible..make sure that there are no runners,or anything on the boat in the way..<br />also "clear the engine turning<br />"clean bottom to the pickup"<br />put the thing low enough to have the water hit the hole in in by at least one inch..<br />"tip" blow into the hose and see if your speedo work's .."rephrase that !!!<br />apply low pressure to the hose to see a movement of the speedometer dial...if ok <br />then buy a "pick-up and attach..
Dunaruna
Speedo's, AKA - budgie smugglers :p (that's according to my daughter).<br /><br />Glenfiddic.k, single malt 18 y/old scotch (read - scottish) wiskey. Mana from the gods.<br /><br />Follow yor posts, you're kidding, right? I'm getting a brain anurism just thinking about it. ;) .<br /><br />By a cheap handheld GPS and throw the speedo away. They are inaccurate and a waste of time even when they are working 100%. <br /><br />Yes, the cricket is of interest to me (watching, not playing). No matches at present, they need a break before the BIG game (the 'ashes').<br /><br />Aldo
Movie Quote of the Day: "There it is. Now I see it" (Hallelujah Trail, 1965)
