newtoboat101
Thread starter- Joined
- Jul 9, 2015
- 420
1988 thompson 240 fisherman fiberglass boat rebuild transom (see pics), my question is now that i have removed everything from the transom (trim tabs ,kicker motor bracket speedo tube ,and some other hardware) do i (1) replace the transom wood and fiberglass on the inside first then fill in the holes on outside ,or (2) tape the back side and fix holes then replace transom inside or (3) put a layer of 1708 on inside of transom then apply wood and fiberglass over it then fill holes from outside ,i think all the holes in transom has me a little concerned and intimidated ,any help or suggestion appreciated .some of the holes will be reused ,kicker motor bracket will be moved slightly thank you
