bob johnson
- Feb 25, 2009
- 4,304
Thanks, Capt. Bob. But if I disconnect the steering arm, how could it still be attached to the mid-section?
the steering arm is NOT this little piece that falls to the ground when the bolts that hold the motor mounts to the block!!!!!
you are NOT taking the steering arm off!!!...you are ONLY disconnecting it from the mounts!!!!..the bolts go through the steering arm and through the mounts and into the block!!!!!... the steering arm is held in its place in other means...it is part of a pivot tube/shaft that goes DOWN through the transom bracket and it held on from the bottom.......some how you are totally missing how the steering arm is attached to the complete motor!!.....very seldom does a steering arm come off.....power heads come off 10 times more often than a steering arm...maybe even MORE!!
bob
