Thermostat Location
Greg22
I have a 1990 Johnson GT150. Where are the thermostats located? Thanks.
OBJ
Re: Thermostat Location
Hi Greg...<br /><br />The thermostats are located at the top of each head. Look for a four bolt cover on each head. The T-stats will be behind them. Be aware that there is a spring that holds the t-stat in place. So if you do take the cover off, hold onto it.
Greg22
Thanks OutboardJim. I found them and removed the one. My motor was getting much hotter on one side, than the other. However, my horn was not going off. I have been having trouble with my motor running rough and no power for the first 10 minutes or so. This happen everytime I first start out. Once the motor runs for a few minutes it runs great. Not sure if the thermostat is bad, however it sure looks old. I am going to pick up a new one and give it a go. I am going to also replace the plastic device as well. Any input?
buttonhook
sounds like one side is not firing until warm there is another post sim. to this one check out the answers to it. It might help some.
