Re: thermostat installation
I haven't replaced the thermostat on my RDS-20, so I'm not sure. I did take the cover off, but it had a new thermostat in it already. I didn't notice the notch, though.<br /><br />Is this a notch in the top outer edge? If so, it could be there to line up with a mating raised area on some engines. OMC used the same thermostat on a bunch of engines for a long time.<br /><br />I can't see that it would matter much, frankly. The thermostat opens up vertically, so I doubt that alignment would make any difference. If there is a raised area in the housing casting that matches the notch, well, then, that would be a different story.<br /><br />Sorry I can't give you a definitive answer, and Paul Moir doesn't seem to be around today. Logically, though, I don't see how it would matter.
