Hi folks.
I have the exact same problem (like in the picture of the linked thread), But I couldn't understand how guy48065 solved the problem.
I solved the problem by adding two extra layers of gasket. (Manually cut them). Without the gasket the spacer hits the housing, 1 gasket not enough, at it leaks all over the place.
I tried to solve the problem by removing O-ring (cork) first, but protruding was still there. I guess the spacer is manufactured in wrong dimensions.
A solution also maybe cutting the spacer where it faces the thermostat. But it is very hard material.
The only explanation I can think of is the materials change dimensions with heat (metal housing, gasket, O-ring etc.) as time goes by and originals parts don't fit anymore.
BTW, can you help me finding that manual of that page shown?
Thanks
Thanks
