Thermostat housing white plastic sleeve?
ZafSC
Hi folks.
I have the exact same problem (like in the picture of the linked thread), But I couldn't understand how guy48065 solved the problem.
I solved the problem by adding two extra layers of gasket. (Manually cut them). Without the gasket the spacer hits the housing, 1 gasket not enough, at it leaks all over the place.
I tried to solve the problem by removing O-ring (cork) first, but protruding was still there. I guess the spacer is manufactured in wrong dimensions.
A solution also maybe cutting the spacer where it faces the thermostat. But it is very hard material.
The only explanation I can think of is the materials change dimensions with heat (metal housing, gasket, O-ring etc.) as time goes by and originals parts don't fit anymore.
BTW, can you help me finding that manual of that page shown?
Thanks
Fun Times
Hi folks.
Thanks
What engine model, year and/or engine serial number is your engine?
Is the white sleeve a Mercruiser OEM part or aftermarket of some kind?
Did you clean out the old cork gasket that sits in/down first in the thermostat housing (under the thermostat), clean the inner housing and the keyway type slot for the plastic sleeve, put a new cork gasket in, install the thermostat in the "correct position", install the white sleeve all the way down until it touches the thermostat (maybe with a careful light tap needed sometimes), put the gasket with the two brass rivets so good continuity can be connected between the engine and housing helping to add a good ground connection for the two? sensors in the T housing?
